marine diesel < + 400hp and up
Subscribewhat yall got to say about it ?
tommymonza
close
- Join DateAug 2004
- Locationnaples,florida
Liked:1,377 Times in 600 Posts
My money is on the 450 Yanmars in front of some Arnesons and call it done
Is anyone doing anything with marine Duramaxes these days? I saw a marine Gale Banks built Duramax in one of the truck magazines a few years ago and it looked impressive! I beleive the article said it was built for a military vessel.
Diesels are great for moderate speed, but have a limited rpm range. If you set them up to run hard on top, you end up with injectors that have issue at lower pressures and pulse widths and finding turbo setups that will move the air you need and still spool up somewhat decent is very difficult. They also weigh a ton and generate an insane amount of heat under full load.
Not saying it isn't cool or that they don't produce a ton of torque.. You'll definitely need arnesons to keep from destroying drives.
Quote:
is that a new model they came out with?Originally Posted by tommymonza
Or if youre into the one off stuff like myself check out this Duramax 5 speed Allison setup PPE built. A++ for thinking outside the box. Rpm issue solved. Not sure how long that Allison will last but who cares!
https://www.youtube.com/watch?v=Y4ugzTL2y1U
Gimme Fuel
close
- Join DateOct 2010
- LocationHemlock, MI
Liked:128 Times in 75 Posts
This is one of the many hairbrained engine builds that pops into my head from time to time. It may work, it may not. Seeing Banks putting superchargers on top gets me thinking way outside the box. Cool stuff happens outside the box. Why use turbos at all?
I would like to see a Duramax built with some Big Block mentality for marine use. Forget turbos to simplify things especially exhaust. Use a large procharger instead with regular intercoolers, they can make more than enough boost. Good rotating assembly, ported stock or aftermarket heads with larger valves, custom camshafts, fabricated intake manifold similar to Holley Hi Ram with a large throttle body. A conventional set of headers made to fit the duramax would fit the bill and be much easier, possibly much cheaper than exhaust and turbos I would think, and would result in much less piping/plumbing. Heck, how far off is the port spacing from a BBC? Could an adapter be machined to fit to use existing headers? Build her to spin 4000 rpm, that isn't out of the realm of possibilities at all.
As far as Cummins, Duramax, Powerjoke......ect, same theory applies. Your preference. I just like the v8 look and sound
I would think that build would have the potential for some serious HP let alone torque along with reliability. But of course I could be wrong. I need to win the lotto so I can be mad engineer/scientist with this crap.
