Mistress repower #2 begins.... >
Old 12-05-2014 | 04:37 PM
Full Force's Avatar
Default Mistress repower #2 begins....
As most know I repowered the Mistress 2 years ago, bought a boat to get the engines and it turned out to be a nightmare.....
So.... today I ordered my NEW Dart blocks, and Eagle rotating assemblys for both, will be 540CI all machinework done at Victory Engines in Cleveland, great guys! they never let me down... ever...
I will post pics and info along the way, with the help of my best buddy Scott (Lake Effect) and guys like Joe (Mild Thunder) all issues will be addressed and hope to have new reliable 650-700 hp when I am done...
boat ran 73.4 with 600 hp and TRS so lets see what happens!!
Full Force is offline
Old 12-05-2014 | 04:47 PM
vintage chromoly's Avatar
Good for you Tim!
Good choice on the machine shop as well!
vintage chromoly is offline
Old 12-05-2014 | 06:05 PM
Full Force's Avatar
Originally Posted by vintage chromoly
Good for you Tim!
Thanks, Ray has always made things PERFECT for me....ALWAYS
Old 12-05-2014 | 06:20 PM
Good luck with the rebuild
sonic700 is offline
Old 12-05-2014 | 06:50 PM
Full Force's Avatar
Thanks bud!!
Old 12-05-2014 | 07:34 PM
jeff32's Avatar
what is your estimated budget on the build?
jeff32 is offline
Old 12-05-2014 | 07:48 PM
Full Force's Avatar
well, from what I have figured so far...
blocks and rotating assembly's includes file fit rings, Clevite bearings, ARP2000 rod bolts 7600 for both
about 1000 each engine for machining and cleaning, setting clearances and all that...
I need to buy cams working on maybe a nice used set from Mild Thunders buddy ( nearly identical engines)
Morel lifters...550?? x2
oil pans 4-600. X2...
gaskets, oil and BS who knows 1000.00 for all that
heads were done last year, will most likely need better springs for new cams, so whatever springs are I can install them.
Honestly I figure 15,000.00 for both give or take, I would like to dyno them if I can also... so we will see...
Old 12-05-2014 | 07:54 PM
Are your sure ARP 2000 rod bolts? Sorry, couldn't help myself.
abmotorman is offline
Old 12-05-2014 | 07:55 PM
Full Force's Avatar
HAHAHHA here go lol
Old 12-05-2014 | 08:45 PM
bigboat28's Avatar
Good luck Tim, get it done with all that free time you have, spring is coming hopefully.
bigboat28 is offline
