500HP top end in a 502 MAG >
Old 12-06-2014 | 06:57 AM
Default 500HP top end in a 502 MAG
Would the HP 500 Heads(with the bigger valves) and cam do any good in a 502MAG? The MAG already has upgraded exhaust if that would be an issue.
farmo83 is offline
Old 12-06-2014 | 07:34 AM
F-2 Speedy's Avatar
I think you will see little performance change as far as mph, should also remap the ecm if its MPI
F-2 Speedy is offline
Old 12-06-2014 | 09:12 AM
the deep's Avatar
Fast Singles Club
Veteran: National Guard
I will be selling a complete HP500 top end soon should you decide to go that route . Stock carb is a Stage V by Nickerson .
the deep is offline
Old 12-06-2014 | 09:19 AM
need to do heads(with new valve springs/rockers) cam, intake/carb, exhaust to make work correctly, heads alone on a EFI not worth it
ezstriper is offline
Old 12-06-2014 | 11:25 AM
The bottom ends on the carbed 500hp and carbed 502mag are the same.
The 500EFI has better rods.
Griff is offline
Old 12-06-2014 | 05:14 PM
if carbed ,yes
if mpi,,then yes after remap.
sutphen 30 is offline
