Windshield Foam >
Windshield Foam
Windshield Foam
Old 12-09-2014 | 09:58 AM
Default Windshield Foam
Anyone know what velocity used as "foam" behind the windshield where it mounts to the boat? I want to say Kenny told me years ago they used some sort of foam from home depot?
thanks for any answers
John
JohnSchiavarelli is offline
Old 12-09-2014 | 07:08 PM
Relaxing's Avatar
I used this, but found it in a longer roll.
http://www.homedepot.com/p/MD-Buildi...6593/100355591
Relaxing is offline
Old 12-10-2014 | 08:09 AM
Thanks Relaxing. Did you do just one strip all around or double it up? I don't suppose you took any pictures? :-)..
Old 12-10-2014 | 07:35 PM
Relaxing's Avatar
John
I did 1 strip all the way around, and no pictures sorry.
Relaxing is offline
Old 12-11-2014 | 08:20 AM
I used 1 layer of 2" wide black neoprene pipe insulation that I got at a plumbing supply. Two layers is too thick and DON'T over tighten the screws especially where there is a gap between the lexan and the deck.
Vicious22 is offline
Old 12-11-2014 | 02:35 PM
Velocity Vector's Avatar
Crazy Energy
http://www.go2marine.com/product/154...UOXxoCeDvw_wcB
1/4" to 5/8"
Velocity Vector is offline
Old 12-22-2014 | 11:21 AM
Forgot to reply and say thank you guy for the info.. I was able to get some from Wholesale marine. Looks like it will work great..
Re-doing the painted graphics on my 2001 Yellow and Purple 260. (Not chaging the paint patterns, just redoing the same graphics). figured I would fix the windshield foam in the process. Also, switching the 540 carb to a Holley HP EFI setup. Almost ready for the DYNO. Should be "almost" like new when done.
Old 12-22-2014 | 03:56 PM
Crazy Energy
cool beans
Old 01-29-2015 | 02:44 PM
So I went with a 5/8thick foam. Anyone else use something that thick? Seems as if there is a decent gap between the glass and the boat. I would think the foam would compress a bit over time though and need to be tightened down. Thoughts?
Old 02-02-2015 | 11:09 AM
Im Redoing a cockpit on a 280 also redoing windscreen seal give me a call i will tell you what i did Kenny 407-402-0300
letstalkboats is offline
