Fuel Stabilizer or Octane Booster? >
Old 12-24-2014 | 08:51 AM
Default Fuel Stabilizer or Octane Booster?
Anyone have experience with Torco Racing fuel octane booster vs. StaBil stabilizer as it relates to engine performance? Basically, I'm wondering which is better (for the gas). With StaBil, I understand it slows or prevents Octane degregation. With Torco, it boosts Octane, presumably for some period of time, but doesn't hold it at that boosted level. I'm leaning toward the use of StaBil with 87 octane, rather than Torco that will boost the Octane in the short run, but have the Octane level fall back down (to 87 or lower) in some period of time. Lets assume both products over a 30 day period, which would you use?
imartin is offline
Old 12-24-2014 | 09:09 AM
they do totally different things...the torco booster is just that boost the octane level a certain # of points, the stabilizer again just does that...keeps the gas from breaking down over a period of time when it sits...as far as time a lot of factors will come into play there...you might ck with torco on the time before breakdown on their additive...
ezstriper is offline
Old 12-24-2014 | 09:13 AM
Knot 4 Me's Avatar
May I ask why you feel the need to use either product over a 30 day period? Assuming your application requires 87 octane, I don't see why you wouldn't just use pump gas sans any additive.
Knot 4 Me is offline
Old 12-24-2014 | 09:34 AM
On Time's Avatar
I have used Sta-Bil Marine (blue) for the last 4-5 years it has been on the market with excellent results and zero issues. I used the red stuff before that and it worked fine too. Store the tanks full with full dosing of Sta-Bil and run them out the following year. There is a new Sta-Bil 360 out I have not tried yet. I always use 93 octane for a 4-5 mo storage period in case there is a drop in octane.
On Time is offline
Old 12-24-2014 | 09:50 AM
I have tested pump gas up to 4 years old, 38 samples total in sealed plastic containers and vented containers. No drop in octane has occurred. Out of 38 samples between 87 - 93 octane has never been below the advertized in in ALL cases the actual octane is .75 to 1.2 octane higher than advertized. 89 octane advertized pump "minimum" will be 90 octane.
Some of this fuel however is foul, brown and is unlikely to burn even with a blow touch, but the octane is ok. octane is not the problem. if in doubt add a fuel stabilizer to cut off the oxygen to the fuel to minimize the loss of fuel addative's.
James is offline
Old 12-24-2014 | 12:06 PM
For 30 days, nothing is needed. I would use Stabil for 90 day plus lay ups.
Griff is offline
Old 12-24-2014 | 01:28 PM
BUP
This should clear all matters up totally so read it very carefully to understand fully . This report is from a company BP that makes / blends / formulates gas in the million gallons per week. Not from someone has no experience with fuel formulations or has never blended gasoline. Also depending on your testing equipment for the do it yourselfer how spot on is the your testing equipment you are using. Anyways the facts below and end of story.
http://www.bp.com/content/dam/bp-cou...icle-tanks.pdf
And I will say it again the smartest guy about any fuel questions I have ever met is Tim Wusz from Rockett brand fuels.
www.rockettbrand.com
BUP is offline
Old 12-24-2014 | 01:39 PM
BUP
A good read
http://www.rockettbrand.com/download...Jan%202011.pdf
I got to meet some Nascar guys and a few of the builders at PRI and they started talking about fuels & racing fuels plus topics about Ethanol fuel that they have to use at ever race. Anyways Tim Wusz name came up and the first comment from their mouths was 'that guy forgot more about fuel than anyone even knows about the subject " Anyways thought it might worth mentioning since I always have hit Tim up with a zillion questions when I run into him or in his classes at PRI.. Really is a wealth of knowledge and a really nice guy on top of.
If you are looking for quality racing fuels - give Rockett Brand fuels a call. I am not affiliated with them either and have no reason to post what I did except for passing on some very solid advice and answers to the topic..
BUP is offline
Old 12-24-2014 | 02:08 PM
Thanks everyone. As suspected, im going to focus more on the stabilizer than the booster. I plan to run 87 oct as Merc calls for, and will throw some Stabil Marine in for good measure to keep the Octane steady. I said 30 days, but on second thought, probable 60 to 75 more realistically. Much appreciated!
imartin is offline
