Piston top displacement stats needed
Does anyone know the displacement amount consumed/lost by the protrusion in the stock 502 pistons - je700
This is the top style I'm talking about since evidently they made several top styles even under the JE700 stamping
Its a very small dome. Its not much, I wanna say 3 or 4cc positive displacement. Same piston used in GM crate ZZ502, 502HT towing engine, some merc 502's, etc. Its GM part #12533507, just made by JE for General Motors. Typical 502 with 118cc chamber heads, .040 head gasket, usually ends up around 8.75:1 ballpark.
I thought I'd call you as a bundle of information and you'd be all impressed and you went and spoiled that..... Haha
Left you a message late afternoon. My crank is in, and I've got the piston in to give you any other measurements you need.
Eric
http://www.jepistons.com/Catalogs/SR...placement.aspx
