Flywheel balancing >
Flywheel balancing
Flywheel balancing
Old 01-08-2015 | 04:58 PM
Default Flywheel balancing
I have neutral balance flywheel from an automotive application I plan on using on my 540 ci build. The rotating assembly was balanced without the flywheel supplied to them. Would it make sense to have this flywheels balance checked?
tbanzer is offline
Old 01-08-2015 | 05:42 PM
Ayuh,.... If they balanced the rotatin' assembly, For a neutral balance flywheel,....
It oughta be just Fine,.....
Bondo is offline
Old 01-08-2015 | 08:39 PM
Assuming the crankshaft is the internally balanced type. If it isn't they should asked for a flywheel and harmonic balancer.
payuppsucker is offline
Old 01-08-2015 | 10:41 PM
i would have it checked just to be sure..its only 50 bucks..
FIXX is offline
Old 01-10-2015 | 06:22 AM
but what are we rechecking? if the flywheel is neutral? or if crank is neutral balanced correctly or not? they coulda been external balancing with a generic supposedly correct for application flywheel and balancer. i think those answers are necessary from place that did the balancing first.
dereknkathy is offline
