Re-Build or Re-Fresh
Old 01-11-2015 | 08:25 PM
Default Re-Build or Re-Fresh
Guys
As bad as I hate to admit it, my wife asked me this question and I did not know the correct answer. What is the difference between an engine rebuild and a refresh?? I know one will involve more parts and $$$. But, at what point is it a rebuild and not a freshen up ??
Thanks, David
David H is offline
Old 01-12-2015 | 05:34 AM
I would have to put it like this.....
A freshen would most normally be new bearings, seals, minor machine work and maybe valve grinding.
A rebuild would be after you were leaving your favorite hangout and hold it wide open for a while then all of a sudden.......BOOM GOES THE DYNAMITE!
Maybe this will help??
Jonesyfxr is offline
Old 01-12-2015 | 07:12 AM
To me refresh wouldn't really involve bottom ends. Basically I would put refresh in top end work and rebuilds would include bottom ends. That's how my brain hears it.
Crude Intentions is offline
Old 01-12-2015 | 07:34 AM
Many things to many people. For us old guys it used to mean using the crank/ rods/ Pistons (if the bore is ok), valves and just putting new rings. Bearings, valve job, valve springs in.
I know some would cring but when we were young and broke we would label where the lifters came out and reuse or resurface them at the machine shop where my buddy's dad was a tool maker.
Wildman_grafix is offline
Old 01-12-2015 | 08:30 AM
^^This is how my father used to do it when I was young^^
Old 01-12-2015 | 08:53 AM
So now I feel just a little bit older!
LOL
Not that I would recommend this now
Old 01-12-2015 | 09:11 AM
LOL
Sorry didn't mean to make you feel older!!
And I concur with your statement about reusing lifters and marking them.
Old 01-12-2015 | 10:37 AM
Tom A.'s Avatar
I agree with this.
I will add that a refresh is done prior to going boom, all cylinders have good compression, and you are basically just replacing the worn parts (rockers, springs, guides, etc.)
Tom A. is offline
Old 01-12-2015 | 04:53 PM
Thanks for the input guys. That's kinda what I thought also. I have he 525 out. It did not go boom!!!! Just some blow by. The plan is to strip it down all the way and use the crank, rods, and pistons. If still good. New valve springs and rockers for sure....
David H is offline
Old 01-12-2015 | 07:01 PM
Originally Posted by David H
Guys
Thanks, David
Or Reused........that is what Cobra does!
Jupiter Sunsation is offline
