600SC mechanical fuel pump ability?? >
Old 01-12-2015 | 03:39 PM
Full Force's Avatar
Default 600SC mechanical fuel pump ability??
I rund the Merc 600SC fuel pumps on my gen6 engines, I had 600 hp last season zero fuel issues, how much HP will that pump feed safely? I am shooting for 675-700 it looks like, I do not want to run Electric if I can avoid it.
Full Force is offline
Old 01-12-2015 | 04:18 PM
I run the KE pump heads rated for 120ghp on my mech pumps with 0 issues close to 800hp
Rbesola is offline
Old 01-12-2015 | 04:51 PM
i believe a merc 600 sc pump is a carter 130 gph. im not impressed with them, i would look for a holley pump with more gph. the merc 800 sc ran holley 180 gph
cig92 is offline
Old 01-12-2015 | 05:37 PM
I have run the KE pump head for about 8 years also. If I use anything but Shell 93 the boat coughs under load. It has not done it since I switched to the Shell 93. I have between 550 and 575 hp.
Old Navy is offline
Old 01-12-2015 | 07:59 PM
You have dart blocks now with fuel pump provision?
I'd go with a pump like this #9373
http://www.bakerengineeringinc.com/P...oCamParts.aspx
MILD THUNDER is offline
Old 01-12-2015 | 08:32 PM
Full Force's Avatar
Hmmm I was hoping to just use the sea pump ones because I already have them, joe that link I just see oil pans and such? Think I should go
Back to other style pumps huh?
Old 01-12-2015 | 08:47 PM
icdedppl dan has a pair that i think are brand new that he is not going to use.pm him and check.
mike tkach is offline
Old 01-12-2015 | 08:49 PM
Full Force's Avatar
Cool, thanks.... I just bought his breathers, I guess I will have to find sea pumps or block mine off, just sucks I am plumbed for the sea pump driven pumps, it's not the end of the world though.... its just added to list haha
Old 01-12-2015 | 08:52 PM
You need to click "parts" at top right of screen, then click "mechanical fuel pumps"
Old 01-12-2015 | 09:04 PM
Full Force's Avatar
Duh, also sent Dan a message to see, I may have to buy that stuff later but looking into things I need now...
