Has anyone run the 1st design SCX-4 lower and switched to the 2nd design SCX-4 lower >
Old 01-15-2015 | 10:04 AM
1 MAIDEN AMERICA's Avatar
Default Has anyone run the 1st design SCX-4 lower and switched to the 2nd design SCX-4 lower
And the results?
1 MAIDEN AMERICA is offline
Old 01-15-2015 | 11:32 AM
Do you have pics of both?
Pokher Ace is offline
Old 01-15-2015 | 02:44 PM
Mr Gadgets's Avatar
Charter Member #601
Here are some pics from Imco's web site.. I am also interested in hearing about the differences between these two lowers..
[ATTACH=CONFIG]535706[/ATTACH][ATTACH=CONFIG]535705[/ATTACH]
Second design is on the left.
Attached Thumbnails Has anyone run the 1st design SCX-4 lower and switched to the 2nd design SCX-4 lower-scx4-1300.jpg   Has anyone run the 1st design SCX-4 lower and switched to the 2nd design SCX-4 lower-scx4-xf-6_4.jpg
Mr Gadgets is offline
Old 01-16-2015 | 06:53 AM
I have the new design where the skeg goes almost to the tip of the nose cone. I was told that they redesigned it this way to help break the water and ehlp settle the stern of the boat. I never had the other design but I can say I dont have trouble with stern lift. SHould also be noted that I have normal scx but thought I would comment since we are talking about lowers.
drpete3 is offline
Old 01-16-2015 | 10:27 AM
Thanks for posting pics, curious on feedback from new design
Old 01-16-2015 | 11:10 AM
Please note. The new design does not have a slit in the nosecone for water pick up like my old sc. So you need either external water pick up or modify the lower to open up the small hole that is there
drpete3 is offline
Old 01-18-2015 | 07:31 AM
I have run both and running the new style,it gave my boat a little more control and handling.Also it still has the low water pick up on the bullet,drive has built in cooler that runs through this pick up.[ATTACH=CONFIG]535819[/ATTACH][ATTACH=CONFIG]535820[/ATTACH] Also on my single engine application I needed to add a torque tab to prevent blow out at high speed,very happy with it.
Attached Thumbnails Has anyone run the 1st design SCX-4 lower and switched to the 2nd design SCX-4 lower-image.jpg   Has anyone run the 1st design SCX-4 lower and switched to the 2nd design SCX-4 lower-image.jpg
pro27 is offline
Old 01-18-2015 | 05:44 PM
GAZ
This is confusing to me because I have the new style SCX lower. It has a water pickup on the front of hte nose. I haven't made it larger and it works just fine.
You are saying it doesn't have a slit in the nose cone.
But you are also saying you have to open up the small hole that's there?
GAZ is offline
Old 01-18-2015 | 06:58 PM
Pete you have the SCX with the newer lower
That's different then the SCX-4 which also has a new lower
offshorexcursion is offline
