SSM 3. fits TRS upper?
Old 01-16-2015 | 08:34 AM
Default SSM 3. fits TRS upper?
And if so, is it a viable alternative to redoing the transom, relocating the engine and converting to Bravo? Or are they too old, scarce and pricey?
dereknkathy is offline
Old 01-16-2015 | 08:58 AM
No. It doesn't fit TRS anything
MILD THUNDER is offline
Old 01-16-2015 | 09:00 AM
Ssm 2 lower uses trs upper. Only thing you can use when swapping to 3's from trs is the trans itself, different tail stock and the boat.
Unlimited jd is offline
Old 01-16-2015 | 09:06 AM
And the 2 is pretty much extinct, right?
Old 01-16-2015 | 09:28 AM
Yes
Old 01-16-2015 | 10:00 AM
if they can be found, what props fit?
Old 01-16-2015 | 10:10 AM
Jamie did you ever sell the #3s you had?
adk61 is offline
Old 01-18-2015 | 10:21 PM
lil red has some #3's in SWAP section
I'CE is offline
Old 01-18-2015 | 10:35 PM
Team Archer on the board had some #2 lowers I think
I'CE is offline
Old 01-19-2015 | 04:22 AM
i have been convinced it isn't enough of a performance improvement to go from something where parts are hard to find(TRS) to something where parts have to be fabricated.
