bravo 1 and 2 diff? >
bravo 1 and 2 diff?
bravo 1 and 2 diff?
Old 01-26-2015 | 05:17 AM
Default bravo 1 and 2 diff?
i think i just screwed up. bought a parts boat for the bravo setup. 24 arriva. (GO BAYLINER!!!) so i looked it over and all was in nice shape except shot interior and cracked 454 block. i go home and start looking at bayliner forums to see if i can find anybody needs misc junk off this hull and i see all 454 arrivas were built with bravo 2 drives. (here is an addendum to worst perf boats ever built thread...bayliner marketed it as a perf boat and put sundancer-houseboat drives on em!) anyway, i think i have a 2 inch space above the 23 mirage prop. (not here gotta pick it up yet) when you put a spacer in a B1 to lower the x it goes above the cav plate, correct? and what makes the driveshaft longer? is there any use as a perf lower for somebody who put his x higher than he needs? or is this lower only marketable to someone with a cruiser who leaves it in the salt till it dissolves?
dereknkathy is offline
Old 01-26-2015 | 06:28 AM
Mbam's Avatar
Offshoreonly Advertiser
Yes, it is above the cav plate. The spacer kits come with longer studs and couplers. So to pull it out you will need stock studs & coupler.
But I have good news - If it has a mirage it can't be a Bravo 2, a Mirage wont fit a B2.
Mbam is offline
Old 01-26-2015 | 06:40 AM
F-2 Speedy's Avatar
I had a 1997 2552 Arriva all stock 454 and a B-1 with a mirage prop, I dont think all your info is correct,
F-2 Speedy is online now
Old 01-26-2015 | 08:45 AM
I am hoping i am wrong. Guy said boat did 60 (wishometer) with 23 mirage prop. Would be screaming at 5500 to 6000 rpm with 1.8 or 2.0 drive.
Old 01-27-2015 | 05:04 AM
[QUOTE=Mbam;4256126But I have good news - If it has a mirage it can't be a Bravo 2, a Mirage wont fit a B2.[/QUOTE]
i missed this second line reading on my phone at work. Whew!
Old 01-27-2015 | 04:49 PM
A drive spacer goes between the upper and lower. The spacer kits include longer studs and a longer coupler to connect the upper and lower shafts.
They may have a smaller diameter Mirage prop on it that was designed for an Alpha drive.
Griff is offline
Old 01-28-2015 | 03:04 PM
Ok. Definately a B 1. Just picked up boat. Anybody need any bayliner parts?
