Merc SC800 supercharger pulley/boost ratio?
I have a 4.75" ten rib top pulley and a 4.5" ten rib bottom pulley,
blower displaces 420ci
On a 540 tall deck I am guessing this would give me 5-6lbs of boost..
Am I in the ballpark here?
the Holley chart for the blower shows 5" top and 5" (1 to 1)bottom giving 5-6lbs on a 540 tall deck..
Thats what I was using as a starting point..
Forgot about under/over driving.
My bottom pulley is the stock pulley from the SC800,,
top pulley have no idea,,..
Just cant find much aftermarket selection for the ten rib pulleys,,
Thats why I thought I would still make 5lbs on the smaller 540..
Of course i was looking at the wrong numbers..
Thanks for kicking my brain into gear,,
I was only looking at the sizes and not the position,
with a bigger top pulley its underdriven regardless the sizes,,
duhh!!
Feeling stupid now....
duhh!!
I am pretty sure the 800sc bottom pulley is larger than 4.5 inches. The 600SC bottom pulley measures 4.60 diameter. I am betting thats prob what you have. Stock 600sc top pulley, was 4.9 inches. Stock 600sc with that blower was a 502ci, made around 5-6lbs with that pulley combo. The 800sc may have used a 4.75" top pulley, but with a larger bottom to get the 18% overdrive, somewhere around 5.6" in diameter. . Sucks cuz not many pulley options with the merc 10 rib setup.
