Throttle conversion
Old 02-06-2015 | 02:38 PM
Default Throttle conversion
I have an '85 34' Scarab with the original single-lever, dual-function controls. I am interested in changing to the separate-function 4-lever controls. The bright red cables installed could be the original cables; I have no history on the boat.
Mounting and placement are the easy part. What should I look for in cable compatibility? Is there a brand or brands that will drop in without needing new cables? Brand recommendations would also be helpful. What are the pitfalls with purchasing used?
Thanks,
Mike
http://postimg.org/image/u6vi5wkyf/
Mike77 is offline
Old 02-06-2015 | 02:50 PM
you will need new cables pretty much no matter what you brand you use. All the offshore controls use 33c cables.
jmrapp is offline
Old 02-06-2015 | 04:29 PM
I'm pretty sure when you get it apart,,the cables may only need adapters to mount to the new style shifters.get it apart and upload some pics will be a big help.
sutphen 30 is offline
Old 02-07-2015 | 08:39 AM
that is a morse unit, should use std 33 cables, so changing won't be a deal at all, did a new boat in 88, morse actually made a set that looked like livorsi, merc etc, almost a drop in swap...
ezstriper is offline
Old 02-07-2015 | 09:48 AM
I should be able to get to it tomorrow and post some pics. Thanks for the help.
Mike
Mike77 is offline
Old 02-07-2015 | 12:48 PM
for the love of me(its been since 2001) i don't remember changing the cable on my boat when I went to gaffrig levers.
Old 02-09-2015 | 04:51 PM
Rookie's Avatar
I did the swap a couple years ago on my Scarab. Cables are not necessary just different cable ends. I did need to cut out the opening for the new shifters.
Halfway down the page in the following link.
http://www.offshoreonly.com/forums/r...rogress-2.html
Rookie is offline
Old 02-09-2015 | 05:20 PM
You will need 4 of Merc part number 845281 to make your cables work. They typically go for around $40 a piece.
endeavour32 is offline
Old 03-08-2015 | 11:52 PM
Finally got the new Kiekhaefer throttles installed. As you pointed out the old unit was a Morse and therefore no cable change was required. I got lucky and the throttle set I got had a set of four cable ends with it.
All I had to do was enlarge the mounting hole, attach the cable ends and cables, and adjust the rigging a small amount for all four cables. Very straightforward job. Thanks for the advice.
Mike
Mike77 is offline
Old 03-09-2015 | 08:43 PM
The cables were the same on mine as well. Went from the Morse to the "K"
murfman is offline
