marine sealant (clear) >
Old 02-17-2015 | 08:52 AM
Default marine sealant (clear)
I just bought a pair of swim step and I was wondering which Clear Marine Sealant I could use to seal all around the brackets with the transom. I know the best stuff is 3M 4200 or 5200 but these products are not available in the Clear finish. I will put some marine epoxy on the exposed wood before installing my bolts. Any idea about what good clear sealant I can use (below water line) ? No problem to find white or black stuff but I really want a clear one.
Thanks.
chaoscube is offline
Old 02-17-2015 | 08:57 AM
Knot 4 Me's Avatar
Check out Boatlife Life Seal.
Knot 4 Me is offline
Old 02-17-2015 | 10:37 AM
I use the clear 100% silocone from DAP lowes carries it...great stuff...I do not think there is anything to "marine" silocone...the 3M are sealer adhesive, 5200 when you do NOT want to remove, neither really what you are looking for and they are messy to work with as well and tend to "run" on a vertical install
ezstriper is offline
Old 02-17-2015 | 10:46 AM
I use Permatex Clear RTV for sealing around exhaust tips.. Should be fine for your application as well
http://www.permatex.com/products-2/p...sealant-detail
http://static.rshughes.com/wm/p/wm-a...0f3efc.pdf?uf=
HyFive578 is offline
Old 02-17-2015 | 10:48 AM
I just reread your post and see you want below water line. The BoatLife LifeSeal might be better..
Old 02-17-2015 | 02:23 PM
I can't find any BoatLife dealer in Canada but will probably import the products on the internet.
Thanks a lot !
Old 02-19-2015 | 07:59 PM
I have found this locally :
http://www.starbrite.com/item/marine-silicone-sealant
Anybody used or know this product ?
Old 02-20-2015 | 09:16 AM
Knot 4 Me's Avatar
Sounds like it would work for you.
Old 02-20-2015 | 10:38 AM
US1 Fountain's Avatar
Ginger or Mary Ann?
A little explanation of sealants. I read the differences before as far as when compared to your home hardware stuff, but couldn't recall specifics.
Silicone around the 3:30 mark
https://www.youtube.com/watch?v=G-aQ...ature=youtu.be
US1 Fountain is offline
Old 02-20-2015 | 01:28 PM
Nice video ! I have found a canadiAn retailer for boat life life seal... I will use this product.
