Water / Meth. Injection >
Old 02-25-2015 | 09:28 PM
cigboat1's Avatar
Default Water / Meth. Injection
Has anyone on here tried a water/ meth. injection on your engines;I know they work well on supercharged or turbo engines but they say you can use them on nonaspirated engines and offer a lot of benefits not to mention 45 to 50 HP per engine boost when used properly and tuned.????? thanks Jim
cigboat1 is offline
Old 02-25-2015 | 09:37 PM
i don,t know about 40 hp but on those hot humid days the cooler intake charge is good for some power.
mike tkach is offline
Old 02-25-2015 | 09:43 PM
BUP
snow performance but IMO the supply tank would not be big enough to support a whole day on the water, I could be wrong.
BUP is offline
Old 02-25-2015 | 10:26 PM
less beer,more water/meth.tough decision.
Old 02-25-2015 | 11:45 PM
That used to be the key to your survival , back in the day , on many turbo builds .couldnt really see a benefit on your mainstream low comp marine build even if you boat on a lake of high methanol content ozarka spring water and they were giving away free scuppers at mcdonalds.if the dyno says high octane gives you zilch , water -alcohol inj prob going to be zilch too
airjunky is offline
Old 02-26-2015 | 01:58 AM
I heard if you put it on a 6.0 diesel you will get 28mpg towing your boat..........
mptrimshop is offline
Old 02-26-2015 | 05:17 AM
We run the Snow performance kits on out drag cars. We have a 12-1 BBC with iron heads and we use it to run cooler and not need as much octane. It works well and we only put 91 ethanol free in the tank. We're still dialing it in.
Jonesyfxr is offline
Old 02-26-2015 | 08:06 AM
we run it on our turbo LS drag car, tried on procharged HP500 could not get to work right...went with much smaller jet than co said and still slowed the boat down when came on, we were only running 5-6 psi...sure with a very small jet could get to work...help ????
ezstriper is offline
Old 02-26-2015 | 08:15 AM
I know what you need!
http://brazzersgear.com/
ICDEDPPL is offline
Old 02-26-2015 | 01:40 PM
I know a local guy who runs it on a blown drag car. he swears by it, but took a ton of tuning to dial it in.
