HP500 carb thermostat aassymbly question >
Old 02-27-2015 | 09:40 AM
Default HP500 carb thermostat aassymbly question
Does anyone have an exploded view of an hp500 carb thermostat housing? I'm wondering if the thermostat goes above or below the brass spacer ring, and what the difference would be between the two placements? Thanks in advance.
PurdueCAT is offline
Old 02-27-2015 | 10:43 AM
it's just a std elec holley choke...not sure what you are asking, not much to them, the coil goes in so that when you go to richer on choke it tightens the choke flap...you can google holley choke and get a pic I would think
ezstriper is offline
Old 02-27-2015 | 10:49 AM
Im talking about the water thermostat in the intake. Not the carb. I put "carb" as to decipher between carburated and efi amongst the merc 500's.
Old 02-28-2015 | 01:00 AM
www.mercruiserparts.com always has good exploded diagrams http://www.mercruiserparts.com/Show_...MOSTAT+HOUSING
Griff is offline
Old 02-28-2015 | 07:10 AM
If you have the housing that the T-stat goes in from the bottom (1 piece housing), its T-stat with spring down then the spacer. If you have the housing that loads from the top (2 piece housing) its T-stat first then spacer on top.
Very important that you do it properly, I had a customer do his own the wrong way and toasted and engine (literally).
brian41 is offline
Old 02-28-2015 | 07:16 AM
So what would happen if the spacer were in first and then the t-stat in the top load style? Trying to make sense of how and why it was designed with the spacer....
