Rub rail paint
neither, you should not paint the rubrail because . . . . well . . . . its there for rubbin
rub rail should not be painted for any reason. Not only does it serve a very specific purpose (see above) there isn't much that will stick or hold up in any reasonable way.
08 OPA High Points Champion
I am not saying one way or the other about painting rubrails. But if you are painting anything aluminum. Scuff it first with a scotchbrite disc than alodine it, prime and paint. But aluminum anything on a boat??? Corrosion is a B*****. But if you are looking for colored rubrails I was thinking about that and found Barbour Plastics. They had some different colored rubrails.
I painted my aluminum rub rail with a 5 dollar can (black) of spay paint from local hardware store. It looks very good. It's a class 6 OPA raceboat-so its on/off trailer alot. When the rub rail rubs aginst a piling and scrapes off the paint, I tape it off and spray that section again. If you want to see pics-go on www.OPARACING.org and look under class 6 for 606 Lock'd Up, from 2 years ago. I havent raced it the past two years-since Sandy flooded my house. Spraying is a cheap way to make it look good-not perfect but pretty good. I'm computer illiterate-if someone can drag over a picture-that would be great. Thanks.
OPA under race teams has 602 and 607 listed no 606. FYI
I believe Cigarette paints and or uses some colored rub rails on their current boats - not all but some. Possible Outerlimits as well
