Optimal Squish >
Optimal Squish
Optimal Squish
Old 03-03-2015 | 09:37 AM
Default Optimal Squish
What would be the optimal squish range for a 454 NA build? AFR cyl. heads 10 to 1 compression.
Jeff
sbslinde is offline
Old 03-03-2015 | 09:52 AM
With good parts .035 would be safe.
Black Baja is offline
Old 03-03-2015 | 11:49 AM
Jeff
Ditching the blowers Jeff?
MILD THUNDER is offline
Old 03-03-2015 | 12:18 PM
No blowers for me. Can't afford what I have now.
sbslinde is offline
Old 03-03-2015 | 12:40 PM
adk61 is offline
Old 03-03-2015 | 01:11 PM
TomZ's Avatar
Keep in mind that .035 is the minimal safe piston to cylinder head clearance. I like a little more of a safety margin myself... mine will go together at .044 (piston .005 in the hole and a .039 gasket). But then again, mine will be blown so a tight quench isn't really necessary.
Just my thoughts... by far no expert.... just my experiences.
TomZ is offline
Old 03-03-2015 | 01:18 PM
I've got less than that on my 632
Old 03-03-2015 | 01:55 PM
TomZ's Avatar
Less than the minimum? If so, can you elaborate on why? Mine at .044 is still considered tight. Books and articles I've read on this subject say that the tighter than the minimum isn't necessary. Just trying to understand is all.
TomZ is offline
Old 03-03-2015 | 02:28 PM
quench/squish supports combustion process by squeezing the charge into the chamber where the spark occurs, also has a cooling effect as the quench area runs cooler than the rest of the combustion area... this will allow for a higher compression ratio to be used and aid in the quality of combustion achieved... properly designed quench is like upping the octane, promotes a better burn!!
adk61 is offline
Old 03-03-2015 | 02:34 PM
"Zero" decking the block will allow tuning quench with the head gasket, the proper spec for desired quench is a debate that's been around since Chrysler was a cowboy!!! compression ratio and chamber design are factors but on average .035-.060 what I've seen in the field
adk61 is offline
