Shift / Throttle controls for single engine, like new also a fiberglass shifter pod
I have a Hardin Marine single engine throttle / shift control assembly. I believe it is cast aluminum. Like new, installed once and removed. One small paint chip on one corner. Trim switch in throttle handle and neutral safety switch included.. $375 plus the ride. Also have a new fiberglass shifter pod if you need that also. $100 plus the ride.
Opening dimensions are 6-5/8 x 2-3/4, fiberglass is 3/16 thick. Depths from the top of the opening down are; 12'' at the front of opening, 13-1/2 in the middle and 14-3/8 in the back of opening.
