Assault heads >
Assault heads
Assault heads
Old 03-04-2015 | 12:52 AM
bigboat28's Avatar
Default Assault heads
Anyone ever used these heads? Good or bad results? Thoughts on these heads?
bigboat28 is offline
Old 03-04-2015 | 05:23 AM
I'm not a fan of parts made in China.
Black Baja is offline
Old 03-04-2015 | 05:26 AM
Full Force's Avatar
Stay away from non name brand heads, I would hope you learned from the mess I inherited, you get what you pay for and after seeing the AFR I just got yesterday I would not even think about going a cheap head.....
[ATTACH=CONFIG]537920[/ATTACH][ATTACH=CONFIG]537921[/ATTACH][ATTACH=CONFIG]537922[/ATTACH][ATTACH=CONFIG]537923[/ATTACH][ATTACH=CONFIG]537924[/ATTACH]
Attached Thumbnails Assault heads-afr1.jpg   Assault heads-afr2.jpg   Assault heads-afr3.jpg
Full Force is offline
Old 03-04-2015 | 05:29 AM
Full Force's Avatar
Chinese Pro Comps look at the port if you can see it, wish I had pics inside Pro Comp ports.... they suck for flow compared to name brand...
[ATTACH=CONFIG]537925[/ATTACH][ATTACH=CONFIG]537926[/ATTACH][ATTACH=CONFIG]537927[/ATTACH]
Attached Thumbnails Assault heads-pro-comp-port.jpg   Assault heads-pro-comps3.jpg   Assault heads-pro-comps5.jpg
Old 03-04-2015 | 08:06 AM
Cheep heads can have many issues one nort often discussed is porting them is a pain as the metal is a bit gooy clogs up the bur quickly. Gets to be a pain picking the material out of the burr.
turbo2256b is offline
Old 03-04-2015 | 09:05 AM
WD40 on the burr
adk61 is offline
Old 03-04-2015 | 09:09 AM
Originally Posted by adk61
WD40 on the burr
I dip the cutting bits in transmission fluid.
sutphen 30 is offline
SB
WD40 on the burr
Works good on the aluminum but not so much for the piece of ham sandwich stuck in the casting.
SB is offline
Old 03-04-2015 | 10:25 AM
WD40 on the burr
God's gift to cutting Al.
Cole2534 is offline
Old 03-05-2015 | 09:29 AM
I would be as much worried about the junk a$$ valves breaking off(which has happened) and destroying everything as the heads being basic POS themselves...
ezstriper is offline
