When did your engine blow? >
View Poll Results: When did your engine blow
WOT
44.26%
Cruise
49.18%
idling around
8.20%
Multiple Choice Poll. Voters: 61. You may not vote on this poll
Old 03-04-2015 | 08:47 AM
Default When did your engine blow?
Be interesting to see at what RPM (peak tq, or peak hp) motors take a dump.
ICDEDPPL is offline
Old 03-04-2015 | 08:56 AM
seafordguy's Avatar
No option of "when it filled up with salt water"???
seafordguy is offline
Old 03-04-2015 | 09:00 AM
Tom A.'s Avatar
Had them blow at both cruising and WOT. Depends on the situation.
WOT - Tired and abused internals - Long story
Cruising - Bad fuel
On a side note, the drives went at peak torque or idle! LOL
Tom A. is offline
Old 03-04-2015 | 09:01 AM
Tom A.'s Avatar
Is that similar to oil pan failure? - That's when the pieces parts blow out the bottom and the oil pan fails to keep them in play.
Tom A. is offline
Old 03-04-2015 | 09:09 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
I always liked the no spark problem:
Piston came up and knocked the spark plug out.
Sydwayz is offline
Old 03-04-2015 | 09:11 AM
SB
Usually a lap or two (or run or two)after the announcer jinx's you by calling you out and announcing " XXXX has some sort of motor in that thing today !"
LOL.
SB is offline
Old 03-04-2015 | 09:33 AM
88Fount33's Avatar
Beak botr
Built 406 small block at 6500 pre-ignition timing took out a piston (#8), top ring chunks pushed into soft aluminum head. Ran it back to house at fast idle, beating and banging as I was on a lake without tow service one late afternoon during the week and NO ONE was on the water. About 2 miles away.
88Fount33 is offline
Old 03-04-2015 | 09:42 AM
I don't have a story, I just want to post on this thread so I can look at ICDED's avatar.
HyFive578 is offline
Old 03-04-2015 | 11:38 AM
I had one go when the camshaft broke in half. Yup, the big end of the connecting rod came right up and broke it in half. At least I was able to keep the carb and intake.
Dangerous Dave is offline
Old 03-04-2015 | 11:50 AM
Bought a set of 2.02 heads. First time out intake valve broke head off. destroyed cyl 1. Beastie kept running the 30p yards to get me back to the dock...
dereknkathy is offline
