Big Chief
Old 03-07-2015 | 10:06 AM
Default Big Chief
Question for the gods... will Big Chief headers fit a conventional 24 degree BBC head?? I've been told different stories from different people... I was of the opinion that the exhaust flange was slightly different
adk61 is offline
Old 03-07-2015 | 10:37 AM
14 apache's Avatar
Same gaskets as standard heads but the angel on the flange is a few degrees different. Top is rolled towards valve cover.
If you want the angel let me know and ill check mine.
14 apache is offline
Old 03-07-2015 | 10:40 AM
The ones I have been around have a standard bbc pattern. It is quite a bit higher obviously, and I think at a slightly different angle.
HaxbySpeed is offline
Old 03-07-2015 | 10:43 AM
Posted at the same time. Thanks for confirming the angle
Old 03-07-2015 | 10:53 AM
I cam across some stelling headers a few years back. they were stamped ''Pontiac" on the flange. No go for me. If I recall, yes, it was the angle that was different at the flange.
MILD THUNDER is offline
Old 03-07-2015 | 03:49 PM
Thanks Haxby, Apache and MT... it was the bolt pattern that concerned me... got stuck with a set of CMI's once that were supposed to be for BBC and they wouldn't bolt up, these would be for my cat.. and I'm using a fixed Y pipe for tail and need to be sure...
adk61 is offline
Old 03-07-2015 | 05:07 PM
GPM
Just curious, are they Big Tubes
GPM is online now
Old 03-07-2015 | 06:33 PM
14 apache's Avatar
Think the header will tilt towards each other around 2" on each side.
Old 03-07-2015 | 07:36 PM
yes steroid tubes GPM and this would be ok being narrower, Apache, I can always run a spacer to make them wider if so needed, but won't work the other way around...
adk61 is offline
Old 03-07-2015 | 08:14 PM
GPM
The 2.375 I ran wouldn't seal around standard exhaust ports.
GPM is online now
