Carb opinions 540's 700 hp... >
Old 03-18-2015 | 11:00 AM
Full Force's Avatar
Default Carb opinions 540's 700 hp...
I am doing 540's afr 325 cc heads bob m cams nearly every person said to see 700 hp I need Dominators and that is my plan but what might be easier option if height is issue? I cannot go higher then my 4150's are now...
Just wanted to see combos and if using Dominators what kinda jetting to start with ...
Full Force is offline
Old 03-18-2015 | 11:17 AM
SB
650hp+ is Dominator territory.
SB is offline
Old 03-18-2015 | 11:33 AM
Should've went with oval ports and quadra jets for the torque you need.... Just figured I'd get that outta the way lol last build I did like that was 80p 84s with p/v's front and rear. 548 with 1050 dominator 640hp. Honestly a 1050 out of the box is prob going to be real close
Unlimited jd is offline
Old 03-18-2015 | 11:39 AM
vintage chromoly's Avatar
Call Dale at CFM tim. He's less than 1/2 hour from your house.
4500 carb is going to be taller than the 4150.
vintage chromoly is offline
Old 03-18-2015 | 03:04 PM
4150 Hp 1000 pro systems carb.
getrdunn is offline
Old 03-18-2015 | 03:24 PM
Full Force's Avatar
Kubic?
Old 03-18-2015 | 03:53 PM
Originally Posted by Full Force
Kubic?
Yes, but with a "C"
Old 03-18-2015 | 04:10 PM
http://cfmperfcarbs.com
Old 03-18-2015 | 05:18 PM
Full Force's Avatar
Thought so....
Old 03-18-2015 | 06:26 PM
For 700hp a 4150 is plenty.
Black Baja is offline
