Thought I would post this for fun >
Old 03-26-2015 | 11:12 AM
F-2 Speedy's Avatar
Default Thought I would post this for fun
Standard BBC cam on the left.............. 60mm billet core on the right
F-2 Speedy is offline
Old 03-26-2015 | 12:52 PM
Looks like a Bob M special. Mine had that same copper colored plating on it. Any idea why it's on there?
payuppsucker is offline
Old 03-26-2015 | 02:23 PM
F-2 Speedy's Avatar
The 60mm cams went in my bud's new motors
Old 03-27-2015 | 08:46 AM
Pay,
It's on there to prevent heat scaling during the heat treat process.
OR
OLDRAT is offline
Old 03-27-2015 | 12:31 PM
Thanks for that info OR. I'd never heard anyone say and I've only seen it on the billet pieces. I suppose the cam is ground after the heat treating?
Old 03-27-2015 | 02:18 PM
rmbuilder's Avatar
MarineKinetics
Originally Posted by 33outlawsst
Standard BBC cam on the left.............. 55MM billet core on the right
Ken,
The cam is a 60 MM, 2304, vacuum degassed, carburized ,AQ, 8620 billet core.
Weapons grade
Bob
rmbuilder is offline
Old 03-27-2015 | 02:42 PM
F-2 Speedy's Avatar
Thanks Bob, I corrected it, I'll touch base with you first of next week,...... the point of this photo is to show how massive the core & journal size is, compared to to the OEM.
Old 03-27-2015 | 03:53 PM
Yes, ground and finished after final heat treat. A thin copper plate prevents having to grind through a carburized layer which can be somewhat thick. The plating would not be necessary if one used a vacuum furnace to heat treat but it's somwhat more costly.
That cam is a sweet looking part and like Bob said, strong and bulletproof.
OR
OLDRAT is offline
Old 03-27-2015 | 07:48 PM
I have put the 60mm in my motor but I used tool steel, Tommy from Cheif got them for me he claims they are strongest you can get and dont wear at all, seem to run good. Very expensive
43sv is offline
