Gas 6.0l vs 5.9 cummins MPG
Old 03-27-2015 | 02:02 PM
Default Gas 6.0l vs 5.9 cummins MPG
Hey guys. I currently have a 2000 6.0 gas suburban 2500. Gets 14mpg highway unladen. I will be towing 10k lbs boat and trailer, radar arch.
Any idea what mileage to expect?
I've also found an 07 cummins drw with a 6pd manual trans I'm interested in. Any idea what the unladen and towing mileage would be with this truck? It doesn't have a bed currently. I'm seeing if there is an economic case to be made here.
Thank you
hogie roll is offline
Old 03-27-2015 | 05:37 PM
cougarman's Avatar
With my old Cummins 12 valve got 16mpg towing.
Not sure about the newer ones.
I use a duramax now
Jon
cougarman is offline
Old 03-27-2015 | 05:39 PM
Hogie- If you keep your speed down around 60 mph you should get about 7-8 mpg. I used to get 8-9 with my 8.1 but the 6.0 will be working harder. Stick with the 2500 Suburban. Air bags will help support the load. I also used a Hypertech tuner and used the Regular tune. Put 89 octane in it for towing.
Wannabe
wannabe is offline
Old 03-27-2015 | 06:39 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
I think you will feel a bit underpowered with that 6.0L gasser/4speed Auto on the Suburban 2500.
I think they were only rated for 9,000 lbs. anyhow.
One of the most important things you didn't mention though:
Axle ratio
What does the Suburban have? 4.10 or 3.73?
The 4.10 will give you a bit more grunt, but will hurt the MPG overall.
Sydwayz is offline
Old 03-28-2015 | 10:01 PM
That doesn't make any sense.
Old 03-28-2015 | 10:02 PM
It's rated for 9,900
Old 03-29-2015 | 01:11 PM
Yeah the 410 hurts mpg when normal driving- but helps towing. The 6.0 will get worse mpg towing a big load but it WILL do it. The Hypertech tuner REALLY helps....
wannabe is offline
Old 03-29-2015 | 07:45 PM
unladen meaning unloaded?
The diesels really shine highway unloaded , especially the pre emission ones.. 6 speed even better. Right now Diesel is cheaper than gas. Thats going to be short lived I`m sure.
Ive always wondered what the DRW takes away in MPG over a single. I think it`s at least 2mpg.
ICDEDPPL is offline
Old 03-29-2015 | 08:01 PM
I just got rid of my srw duramax for a dually, same year trucks, gas mileage is no different between the two. in my duramax I see 20mpg highway and 14 towing close to 10k, and 12 towing 14k
I had a 2000 cummins 4x4 and I got 18 hwy with it and 13 towing 9k
performancems is offline
Old 03-29-2015 | 10:58 PM
+2 on the no noticeable difference between single wheel and dually. Lift kits and bigger tires will knock your mileage down, 2 extra skinny ones not so much. I'd say go with the cummins for all round performance and reliability towing. That 6.0l with an automatic is gonna be straining, where the diesel is just happily chugging along.
kidturbo is offline
