Prop on baja 252 600hp >
Old 03-30-2015 | 04:56 AM
Default Prop on baja 252 600hp
Does anybody know if an 14x27 3blade mirage labbed prop will work on my baja 252 about 620 hp
geggen is offline
Old 03-30-2015 | 07:03 AM
With a custom HP engine, it is very hard to predict what prop a boat will need. Even harder to predict if a custom prop will work on that boat! Only way to be sure is to try it.
kreed is offline
Old 03-30-2015 | 10:32 AM
25 may work I would think you want to spin it up some 5,500 rpm or so. We have a 22ft 650 HP spinning a 27 at 6,000 (boats pretty lite also)
Cole-One is offline
Old 03-30-2015 | 11:46 AM
I have a 26 3 blade , was turned down from 27 . it was done by bbades
$250.00 shipped
fastscarab22 is offline
Old 03-30-2015 | 12:21 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Test whatever you can get your hands on with a "standard" load. Keep good numbers and give us a call. We can help with what you tried and offer some other potential test props.
Brett
[email protected]
bbladesprops is offline
