Whats this "tab" for on this K plane? >
Old 03-31-2015 | 09:30 AM
Default Whats this "tab" for on this K plane?
Saw it on a picture of a boat for sale on FB and thought it was interesting.
Does it line up with the bend on the outer edge of the hull, and help with stability?
TooLateVTEC is offline
Old 03-31-2015 | 09:38 AM
glassdave's Avatar
Neno the mind boggler
i have seen those on some race boats, my guess is stability in turning maybe?
08 OPA High Points Champion
glassdave is offline
Old 03-31-2015 | 10:08 AM
Knot 4 Me's Avatar
Is that a Sunsation? Wayne started putting them on his twin step 32's for some time after a few of them went for a spin.
Knot 4 Me is offline
Old 03-31-2015 | 12:48 PM
I recall a member here (PAST DUE) has those installed on his 280S K-Planes. He has a very fast Formula. I believe he is running over 102 mph now and those tabs help prevent chine walking. See the smooth run in the vid.
http://www.offshoreonly.com/forums/f...la-98-4-a.html
4mulafastech is offline
Old 03-31-2015 | 02:17 PM
BUP
Latham marine has their own version of this as well,
Sunsation used them - it was for straighter tracking and added stability while cornering
BUP is offline
Old 03-31-2015 | 04:01 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
It typically makes any boat they are installed on look like a pair of Yamaha Waverunners shooting a pair of water streams about 15' high behind the boat. I've only seen them on Sunsations.
Sydwayz is offline
Old 03-31-2015 | 04:08 PM
buddy has them on his 32 sunsation
dsmawd350 is offline
Old 03-31-2015 | 04:41 PM
TeamSaris's Avatar
Driver-441
Racer
A lot of old F1 raceboats and Class 5/P4 boats that don't turn the best use them, or just a piece of angle aluminium bolted to the tab. Usually just on the port side.
TeamSaris is offline
Old 03-31-2015 | 05:20 PM
TYPHOON's Avatar
I get it on a race boat with a 90 degree angel to the tab It should help in the turns IMO. Not sure why you would use a 45 degree. If a speedo tube can knock off several MPH imagine what 2 of them will do. High speed turning better is the ONLY reason they would be on my boat until someone proves there is a benefit.
TYPHOON is offline
Old 03-31-2015 | 05:38 PM
TYPHOON's Avatar
Also that only works well IMO if the tabs are installed horizontal on the transom. Its a snow plow if you follow the bottom angel IMO.
TYPHOON is offline
