anyone out there every get water in oil from exhaust sucking back?? >
Old 03-31-2015 | 07:13 PM
Default anyone out there every get water in oil from exhaust sucking back??
ok long story short ive been up down and all around done everything, heads rebuilt, check for cracks, new gaskets, now I pulled the motor and had pressure tested no cracks in the block hold solid pressure!!
there 565 bbc with cams and old hawk manifolds with jacketed tail pipes with tips, pressure tested the manifolds there holding fine... heard a wise tail about big cams sucking back water where the water and the exhaust mix... the only catch is mine mix at the tip outside the boat, not to mention I have velvet trans so its about 3ft from the manifold to the tip
has anyone else had this problem im running out of test to perform???
any input would be apprieciated
sicktrickrick is offline
Old 03-31-2015 | 07:40 PM
Yes it happens all the time, the exhaust should't mix with the water they should be dry all the way out. Big cam race motors are completly dry the run a dump tube out the top or bottom away from the exhaust.
43sv is offline
Old 03-31-2015 | 07:41 PM
14 apache's Avatar
It is very possible. Post your cam specs and someone else might chime in.
14 apache is offline
Old 03-31-2015 | 08:08 PM
If you start the engine on the hose and let it idle you can stand back and look up the tail with a good flash light and see the water running back up the pipe.
Black Baja is offline
Old 03-31-2015 | 08:12 PM
You can take a good look at a T-bone by sticking your head up a bull's ass, but wouldn't
you rather take the butcher's word for it? - Tommy Boy
Keith Atlanta is offline
Old 03-31-2015 | 08:18 PM
SB
All the responses above are very good !
And yeh, Tommy Boy was awesome ! Great quote ! LMAOF.
SB is offline
Old 03-31-2015 | 08:59 PM
ok so if water is sucking back how come one motor is filling up with water with the oil and the other motor is not?? im trying to fix my oil water issue?
Old 04-01-2015 | 05:19 AM
check the exhaust gaskets on the water one,,a small leak will make it revert.
sutphen 30 is offline
Old 04-01-2015 | 05:54 AM
Could have a valve to tight. Ignition issue. There are lots of possibilities.
Old 04-01-2015 | 06:52 AM
F-2 Speedy's Avatar
What heads are you running, what exactly is the manifold, could be an intake gasket leak and running into the lifter galley
F-2 Speedy is offline
