complete overhaul on 38 scarab >
Old 04-11-2015 | 06:40 PM
Default complete overhaul on 38 scarab
i thought i maybe able to past on some info from my going project. started with going to freshen up the 510 bowties in boat.
pulled motors , found the motor had came apart at one time. skirt were pretty scuffed up, and a bent 7/16 rod.
next found transom was shot and main stringer.
i will be replacing transom and stringer, repowering boat with pair of 547's.
will post photos as i go,
[ATTACH=CONFIG]539780[/ATTACH]
[ATTACH=CONFIG]539781[/ATTACH][ATTACH=CONFIG]539782[/ATTACH][ATTACH=CONFIG]539783[/ATTACH]
[ATTACH=CONFIG]539784[/ATTACH]
[ATTACH=CONFIG]539785[/ATTACH]
[ATTACH=CONFIG]539786[/ATTACH]
Attached Thumbnails complete overhaul on 38 scarab-3505152_0_230320111900_18.jpg   complete overhaul on 38 scarab-141130_004.jpg   complete overhaul on 38 scarab-141203_001.jpg
complete overhaul on 38 scarab-141203_005.jpg   complete overhaul on 38 scarab-141231_002.jpg   complete overhaul on 38 scarab-150407_008.jpg
flashgordon is offline
Old 04-11-2015 | 06:49 PM
Somebody got a deal on diamond plate lol, looks like a big but rewarding project, good luck!
Unlimited jd is offline
Old 04-12-2015 | 01:01 PM
[ATTACH=CONFIG]539804[/ATTACH]
funny,,,but its not aluminum,,,its a fiberglass board, with the look like diamond plate pattern.
the photo shows a the frt side and then the back side of another piece.
yes,,this will be a big project, but i enjoy fabricating, making stuff, but i will enjoy going for the first blast.!!!!
i plan on enjoying this boat till the end......................
flash...........out
Old 04-12-2015 | 09:18 PM
glassdave's Avatar
Neno the mind boggler
they used a lot of that on the Scarab line all through the late eighties and early nineties count your blessings the stuff in my 38 is red white and blue lol. I pulled a mold off a full sheet of polished diamond plate so I can make it, kinda handy but not as popular as it was back then. I did some in carbon fiber
Attached Thumbnails complete overhaul on 38 scarab-2011-03-09_12-32-38_309-603088285.jpg
08 OPA High Points Champion
glassdave is offline
Old 04-13-2015 | 12:17 AM
Good luck with that flash. I did the same thing to my scarab two seasons ago. I decided to ditch the diamond plate and just painted white. Lots of work ahead.
ramos45 is offline
Old 08-03-2015 | 06:34 PM
steering done....
had to mount inside,,,no room outside..[ATTACH=CONFIG]543850[/ATTACH]
Old 09-13-2015 | 08:58 PM
setting up the new engine mounting....note the alum angle///
[ATTACH=CONFIG]545099[/ATTACH]
[ATTACH=CONFIG]545100[/ATTACH]
[ATTACH=CONFIG]545101[/ATTACH]
Attached Thumbnails complete overhaul on 38 scarab-20150828_193030.jpg   complete overhaul on 38 scarab-20150828_193010-1-.jpg   complete overhaul on 38 scarab-20150904_191655.jpg
Old 09-18-2015 | 12:43 PM
hblair's Avatar
Looking Good!
hblair is offline
Old 09-21-2015 | 06:42 AM
Registered User
Did my engines and transom/stringers two years ago as my all winter project...lots of work to say the least! I see now why these guys charge 4 to 5k to replace the transom only. My 31 Excel didn't have any of the diamond plate material in it...this is the first I've seen it. It's a labor of love for your boat and you'll be happy when your done and know you have a solid boat and nothing to worry about in rough water...keep up the good work!
scarab31 is offline
Old 10-15-2015 | 09:09 PM
thanks scarab31....was alot of work,,,just more time then anything...ended up doing transom and all stringer...
time to assemble 547s...get ready for next yr...
[ATTACH=CONFIG]546544[/ATTACH] ......[ATTACH=CONFIG]546545[/ATTACH]
[ATTACH=CONFIG]546546[/ATTACH]........[ATTACH=CONFIG]546547[/ATTACH]
engine compt done...time for motors....
Attached Thumbnails complete overhaul on 38 scarab-20151015_213525.jpg   complete overhaul on 38 scarab-20151015_213620.jpg   complete overhaul on 38 scarab-20151015_213700.jpg
