Alpha 1 outer water supply hose rerlacement >
Old 04-12-2015 | 06:19 PM
Default Alpha 1 outer water supply hose rerlacement
Hey guys , noticed the outer water hose badly cracked when looking around the outdrive . I was hoping not to rip the whole thing apart . I found some online discussions about it being doable although a P.I.T.A. Anyone done this and have any advice ?
350waternut is offline
Old 04-12-2015 | 07:06 PM
I think that Frisco Jay did a YouTube video.
Jonesyfxr is offline
Old 04-12-2015 | 08:25 PM
BUP
the best advice is to buy the appropriate OEM service manuals per your app(s) along with the special tools needed, I would not put all my eggs in a basket for youtube to provide proper procedures especially for technical repairs. I have customers tell me the same about they go to youtube to try to fix their boats 100 % to a T and many told me about this Frisco guy they have watched. I guess he is in my area (Dallas) -
I just had to check out who in the world he was. - yes he can offer some good advice but I will say this - if he was that great and such a great mechanical do it yourselfer - My question is, if he was that experienced and that great of a boat mechanic , how come he has to spend so much time fixing the boats that he bought, it seems afterwards his boats have big problems after his purchase and he seems so surprised that could happen to him.. Just saying and my own professional opinion.
BUP is offline
Old 04-13-2015 | 06:36 AM
Ayuh,.... If the water hose is old enough to be crackin', the bellows are about too,.....
Get a Kit, 'n service the transom assembly,.... Replace All the rubber parts,.....
The "Expected" service life is 5 years,.....
Bondo is offline
Old 04-13-2015 | 07:06 AM
Biggus's Avatar
Yup, get the entire kit. If you decide to do it yourself, here a tip for ya. Warm up the water hose and lube the end of it and the transom fitting. Push that hose on as far as you can because if you don't the hose will kink when trimmed down and starve the motor of water. Basically, pay attention to the routing as they have a tendency to kink if not installed correctly.
Biggus is offline
Old 04-13-2015 | 09:50 AM
BUP
Mercruiser recommends spraying Power tune on the ID of the waterhose to help with installation..Been doing that 4 ever and it really does make the install of the hose a lot easier.
Buy the OEM service manual is the best advice to start out with. I even have a couple available for that app to sell way less than retail.. Just saying
I do agree buy the transom service kit and watch out which one you get for the Alpha because you can end up with one that's has the smaller ID water hose. Of course this will all depend on the year model of your app. I am taking it you have at least a 1986 thru 1990 app here.
Also it might be wise to do the intermediate shift cable & boot as well,
BUP is offline
Old 04-13-2015 | 10:09 AM
A word to the wise..... Do NOT get the cheap ebay kit!!!!! unless you have a great desire to cook your motor and sink your boat. Now would also be a really good time replace the shift cable too. Alphalphas love new silky smooth shift cables!
phragle is offline
Old 04-13-2015 | 10:14 AM
The job will be easier if you get a long 1/4 inch extension with the wobbley end and the right socket instead of a screwdriver too. And make sure there are no children or little old ladies around when you do it, because you WILL become an expletive emitting master of ceremonies.
phragle is offline
Old 04-13-2015 | 03:12 PM
Thanks for the replies . Yes , the p.o. had the whole out drive re-sealed 3 seasons ago , apparently they overlooked or neglected to change out the hose while they were in there.
Old 04-13-2015 | 03:43 PM
Originally Posted by phragle
the job will be easier if you get a long 1/4 inch extension with the wobbley end and the right socket instead of a screwdriver too. And make sure there are no children or little old ladies around when you do it, because you will become an expletive emitting master of ceremonies.
autozone- not o'rileys or napa -sells a flex shaft extension kit 1/4 & 3/8 about $15 very useful
good luck
GLENAMY 242SS is online now
