trim sender wiring
Old 04-20-2015 | 12:53 PM
Question trim sender wiring
So while doing work on the transom assembly I noticed the senders were not looking to good so I ordered new, well last weekend I had some help available so we figured to knock out this and put things back together again, when was pulling the wires out of the loom I I came up with 2 broke off butt splice connectors instead of the merc plug, this is the trim indicator side, does it matter which way you connect them?
buck35 is offline
Old 04-20-2015 | 01:07 PM
Yes, it will only work one way. If you wire it backwards the gauge will do reverse of the trim.
Jonesyfxr is offline
Old 04-20-2015 | 01:08 PM
phragle is offline
Old 04-20-2015 | 01:19 PM
Thats good to hear, I just didn't want to fry anything hooking it backwards to test it.
It's a 95 bravo deal with an single rocker on the shift lever, halfway to trim all the way to trailer.
buck35 is offline
Old 04-20-2015 | 01:37 PM
phragle is offline
Old 04-20-2015 | 02:26 PM
Thanks phragle!
Where did you find these?
buck35 is offline
Old 04-20-2015 | 05:35 PM
I just googled mercury trim sender wiring, then hit images, I found a whole bunch of stuff last year when I rewired my boat.
phragle is offline
Old 04-20-2015 | 09:35 PM
Thanks again phragle, rob. I'll get the hang of this whole information highway one of these days. Lol
buck35 is offline
