Intake manifold gasket question 454/330
Is there a specific intake manifold gasket kit for peanut port or just use standard oval port gasket?
Was looking at fel-pro # 17340 but port size is std oval not peanut. Any problem here?
Thanks in advance.
Thanks in advance.
Those will work fine. Don't worry about the openings being larger.
Note: If you have a large oval intake, even with peanut heads, you'll need to use large oval intake gasket.
You have more choices. Below are also for peanut intake, peanut heads:
Here's the latest for peanut intake and heads: it has steel core.
Felpro 1212S3
http://www.summitracing.com/parts/fel-1212s3/overview/
If you have the electric choke, and want the exhaust crossover's closed for a little more performanced (less intake heat)
Felpro 1210:
http://www.summitracing.com/parts/fel-1210/overview/
Felpro 1212S3
Felpro 1210:
