trailer wheel cylinders
So I've been working on my trailer, replacing most parts to include wheel bearings, seals, grease system, and brake shoes. I have 12" free backing drum system on 4 wheels. I went to replace the brake shoes, unfortantly most of the wheel cylinders are frozen and need to be replaced as well. I currently have steel wheel cylinders. I have replacements in both Aluminum and Steel. Which would you replace with? The price is about the same. Trailer is mostly used in fresh water, but gets dipped in the gulf a couple of times a year at most. I called the aluminum supplier and they didn't know if it had a stainless liner or not, so I assume not.
