trailer wheel cylinders
Old 04-22-2015 | 02:05 PM
Default trailer wheel cylinders
So I've been working on my trailer, replacing most parts to include wheel bearings, seals, grease system, and brake shoes. I have 12" free backing drum system on 4 wheels. I went to replace the brake shoes, unfortantly most of the wheel cylinders are frozen and need to be replaced as well. I currently have steel wheel cylinders. I have replacements in both Aluminum and Steel. Which would you replace with? The price is about the same. Trailer is mostly used in fresh water, but gets dipped in the gulf a couple of times a year at most. I called the aluminum supplier and they didn't know if it had a stainless liner or not, so I assume not.
racinfast002 is offline
Old 04-22-2015 | 02:08 PM
Cheaper to buy the entire unit. Comes complete on the backing plate.
benjen is offline
Old 04-22-2015 | 02:14 PM
I've already bought everything, just need wheel cylinders.
Old 04-22-2015 | 02:28 PM
I see my bad
benjen is offline
Old 04-22-2015 | 07:13 PM
A lot of times you can put break them loose and they will work fine. Just a thought.
joew. is offline
Old 04-23-2015 | 01:38 AM
I tried but couldn't get 2 of them to free up at all. They are 15 years old so I'm ok with replacing them. Just want to know if I should go steel or aluminum.
Old 04-23-2015 | 03:14 PM
So no one knows? Aluminum vs Steel wheel cylinders?
Old 04-23-2015 | 09:57 PM
If they've been on there for that long and just recently failed, Id replace with the same kind. If you're dipping in saltwater, I'd go alum.
high bid is offline
