how many quarts? >
how many quarts?
how many quarts?
Old 04-24-2015 | 06:38 AM
Default how many quarts?
I have a mark IV 454 that has the mercrusier cast aluminum pan p/n 47552 on it but the previous owner put a universal dipstick on it that I dont believe is accurate. I was wondering if anyone is familiar with this setup. Only info i can find is its a 7qt pan. If it is does that mean the engine takes 7 qts total or 7 1/2 qts due to the filter and cooler?
jaybird82 is offline
Old 04-24-2015 | 08:28 AM
I have a 7 qt stamped pan. When I do an oil change I buy 8 quarts. 7 go in the pan and most of the other goes into prefilling the filter.
Quick2500 is offline
Old 04-24-2015 | 08:38 AM
that pan holds 8 qts.i have them on my 1990 sea ray with 340 hp engines.they were also used on the 420 hp engines.
mike tkach is offline
Old 04-24-2015 | 01:25 PM
Mike tkach when you do an oil filter change 8qts is all yours takes total and its full?
Old 04-24-2015 | 03:34 PM
Rookie's Avatar
Drain oil, change filter, fill w/ 8qts, mark it, run engine for a bit, check oil, add accordingly till at previous mark.
Rookie is offline
Old 04-24-2015 | 04:43 PM
:erna ehrung004:
I've got the same ones. Couldn't have said it any better.
getrdunn is offline
Old 04-25-2015 | 12:13 AM
yes,it will show slightly over full but after you start it and wait a few minutes after shutoff it reads to the full mark.
Old 04-25-2015 | 08:45 AM
Mike - novice question. In checking the oil - should the boat be in the water or is on the trailer/lift etc., ok to get an accurate reading??
thanks
3pointstar
3pointstar is offline
Old 04-25-2015 | 09:14 AM
in the water,it has no trailer.37 feet long and 12.5 wide.
Old 04-25-2015 | 02:57 PM
Thanks fellas!
