raw water strainer >
raw water strainer
raw water strainer
Old 04-25-2015 | 05:24 AM
Default raw water strainer
might be daft but was wondering how you keep the engine free from silt and rubbish and was looking online at sherwood raw water strainers 1 1/4"
are they for protection for other pumps and stuff and not to put inline with the leg water intake ? i was thinking about fitting one before the oil cooler but didnt want to do something real daft and restrict the water flow and blow the lot. it didnt have one before.
russell
Red Roar is offline
Old 04-25-2015 | 10:56 AM
Stormrider's Avatar
JC Performance Engines
These.
http://www.hardin-marine.com/c-1505-...iner-kits.aspx
Stormrider is offline
Old 04-25-2015 | 12:08 PM
ah thanks, not sure that will fit as a bit wide i think but does have the advantage of the thing is cleaned from the top.
is an inch big enough ? how do you know what size you want ?
i was looking at these but i am not sure if when mounted i have room under to get the bowl off and out the way but i wasnt sure if they were fit to do the engine water system
http://www.sherwoodpumps.com/en-us/P...ter+Strainers/
Red Roar is offline
Old 04-26-2015 | 09:20 AM
c_deezy's Avatar
1" NPT with 1-1/4" hose adapters will flow plenty of water.
c_deezy is offline
Old 04-26-2015 | 11:58 AM
ah ok thanks thats really helpful.
have to say i like the idea of that Hardin one as its a top loader and if an inch will do then it isnt that expensive actually
Red Roar is offline
Old 05-03-2015 | 08:58 PM
get one thats clear that way you know when you sucked up a bunch of sand and seaweed :P The one that came on my boat is gigantic big enough for something like a big cam cummins haha
sparky24 is offline
Old 05-04-2015 | 01:53 AM
have gone for one that i think will fit best and lightweight and as you say, see through. have also got some see through pipe so i can see the water flow. not in yet but in theory this all looks like it will work
Red Roar is offline
Old 05-04-2015 | 05:48 AM
It should be mounted to filter all of the raw water before it reaches the engine. I installed one after I sucked up a bunch of crushed shells and clogged my heat exchanger which resulted in a long tow on Lake Erie. Good thing I have towing insurance. I like this type because the top is clamped all the way around the edge and is less likely to crack. (the pressure relief system has since been eliminated)
thirdchildhood is offline
Old 05-04-2015 | 10:53 AM
it will be the first in line to the leg intake so should be fine
Red Roar is offline
Old 05-04-2015 | 04:01 PM
Ing's Avatar
Ing
Veteran: Marine Corp
Default Marine Machine
My 24 has Marine Machine raw water strainer. It works great. It even strains out fine sand pebbles that you can catch at crappy launches.
Attached Thumbnails raw water strainer-100_4656.jpg   raw water strainer-100_4657.jpg
Ing is offline
