Prop Nut Torque >
Prop Nut Torque
Prop Nut Torque
Old 05-01-2015 | 06:12 AM
Default Prop Nut Torque
Anyone know what the torque spec would be on the prop nut for a bravo XR ( if there is one)
AB69Z is offline
Old 05-01-2015 | 06:39 AM
55 lbs.
HyFive578 is offline
Old 05-01-2015 | 07:32 AM
Ayuh,..... I use my calibrated elbow, 'n torque prop nuts to "Darn Good, 'n Tight",....
Bondo is offline
Old 05-01-2015 | 07:42 AM
Same here.
Originally Posted by Bondo
Ayuh,..... I use my calibrated elbow, ....
ALL_IN! is offline
Old 05-11-2015 | 06:37 PM
bbladesprops's Avatar
Offshoreonly Advertiser
55 ft/lbs. is snug and then a little extra (about a eighth of a turn).
Brett
[email protected]
bbladesprops is offline
Old 05-11-2015 | 06:50 PM
Brett
So about 60 ft lbs? 65?
55 never seemed tight enough.
Keith Atlanta is offline
Old 05-12-2015 | 02:37 PM
I meant to say is that to get 55 ft/lbs., I make it snug and then tighten it about a 1/8 turn.
I know it is over 55 but not by much. 65 or 75 ft/lbs. isn't going to hurt anything. When 55 was determined by Merc, we didn't want people to overtighten and strip threads. There is also the lock washer to prevent loosening.
Brett
[email protected]
Old 05-12-2015 | 03:41 PM
I torque to 55 and then give it just a little bit more of a turn. The OP asked for the torque spec.. that's what I gave him...
Old 05-12-2015 | 04:11 PM
SB
I tighten it till it's tight.
SB is offline
Old 05-12-2015 | 04:29 PM
Sydwayz's Avatar
Forum Regulator
German method:
Guudenteight
Sydwayz is offline
