Valve Cover Breathers:  What Works? >
Old 05-01-2015 | 09:26 AM
Default Valve Cover Breathers: What Works?
Ok, currently I have the push in K&N breathers on my valve covers for my fresh 540. One on front of odd bank and one in back of even bank. After running last year I would get a little mist of oily mist from my rear even bank breather after pushing it hard. Not enough to signify issues but enough to make a bit of a mess in the bilge. I imagine this is a run of the mill issue after reading threads about it from searching but I couldn't come up with a definitive answer. My K&N breathers are un-baffled and there is no baffle under the valve covers except the stud girdles.
So here is the question: What do I replace my K&N breathers with, the nice looking tall bolt-on aluminum breathers or do I go to a catch can breather system? What has eliminated the issue for you guys as I have read the K&N breathers are notorious for this issue?
Gimme Fuel is offline
Old 05-01-2015 | 09:57 AM
when the oil gets to operating temp there is a steady mist of oil flying around under the valve cover,this mist finds it,s way out of a breather in the back of a valve cover.
mike tkach is offline
Old 05-01-2015 | 10:13 AM
I got tired of fighting this and ultimately went with a catch can system last year.....no more mess.
rvander68 is offline
Old 05-01-2015 | 10:20 AM
That's why I use PCV systems on my motors.
f_inscreenname is offline
Old 05-01-2015 | 10:22 AM
So there is no tube going from breather up to flame arrestor? Or pcv system? Before pcv cars used a metal tube venting crankcase down to the road. You must have some way to get crank vent back into intake air. You also get oil smell at low throttle-speed with your current setup.
dereknkathy is offline
Old 05-01-2015 | 10:29 AM
No PCV or tubing going to flame arrestor. Smell of oil has not been an issue either. I run a custom multi port EFI system and I really don't want to run hoses to my arrestor or into my 2000 cfm throttle body or intake as I would like to go to a clear polycarbonate arrestor soon once it is dialed in. Currently running a 3"x10" SS Babron arrestor. I have tried very hard to keep the top of the motor clean from hoses and wiring.
Old 05-01-2015 | 10:34 AM
phughes69's Avatar
I was tired of the mess on the valve covers on my Corvette, so I installed a catch can system on each valve cover. A way to improve on the catch can could be to route the vapors off the catch can up yo the spark arrestor
phughes69 is offline
Old 05-01-2015 | 11:30 AM
How are the K&N installed? Eddie Young told me to mount the filter 6 inches above the valve cover. This allows the oil to settle out.
Padraig
Padraig is offline
Old 05-01-2015 | 11:54 AM
I ran K&n breathers on my 632 never much below 6000 rpm and never had a drop of oil out the breathers. The breathers were both in the front of the valve covers (wouldn't clear exhaust in the rear).
Black Baja is offline
Old 05-01-2015 | 01:03 PM
Yea, the only one that gets any mist out of it is the rear.
