Low oil pressure >
Low oil pressure
Low oil pressure
Old 05-06-2015 | 10:31 AM
Default Low oil pressure
I get an alrm and my oil press guage drops to zero when i come off plane when running hard for an extended amount of time. This has happened twice .If I run around 3400 to 4000 it doesn't do it. I have check the oil all os good. Not sure what direction to strat to figure this out. Thanks Mitch
Beachwood is offline
Old 05-07-2015 | 07:32 AM
Check the wiring to the sender. Something may be loose and move when the boat decelerates.
Vicious22 is offline
Old 05-07-2015 | 07:37 AM
I did check that doesn't seem to be loose.thanks though
Old 05-07-2015 | 08:37 AM
Years ago - this was a straight 6 165hp Mercruiser- it was a VERY HOT Labor Day - I ran this engine for an extended period WOT. I came off plane and the exact same thing happened- oil pressure went to zero, lights flashed etc. I immediately shut the engine down and brought it back to shore. I let the engine cool off-- checked the oil - and it was full - no milk or anything- looked perfect. I restarted and again no oil pressure -- Took it to my mechanic thinking the oil pump may have broke- or worse. When I called the next day - his associate said that he was out on the lake running around. Turns out nothing was wrong with the oil pump, sensor or wiring -- The oil broke down. All they did was change the oil and filter. Up until that episode I was using a straight 30W oil - Rotella -- Never had one bit of problem. Was told that Merc changed and now the recommended was 20-50W. I changed to this weight and never had any issues whatsoever-- Probably put on a good 200 hours after that before I sold the boat.
3pointstar
3pointstar is offline
Old 05-07-2015 | 08:41 AM
Cool thanks for the info. I am planning on putting a goof 40w in it when i get home from work in a couple of weeks.
Old 05-07-2015 | 07:11 PM
If pressure only drops after running hard how are your oil temps? If oil temps are rising I'd be looking into oil cooler etc..
Powerquest230 is offline
Old 05-07-2015 | 07:13 PM
I dont have an oil temp guage but i will check it and the oil cooler thanks
Old 05-07-2015 | 08:44 PM
ROB FREEMAN's Avatar
Get a mechanical oil pressure gauge. Shoot the oil filter after hard run with laser temp gun. It also recommend Mobil one v twin oil. It doesn't break down under high heat load conditions . Just a couple suggestions. Good luck
ROB FREEMAN is offline
Old 05-07-2015 | 08:47 PM
Thanks for the info. I have been told by several people to try kendall gtx 40w with a fram hp filter.
Old 05-07-2015 | 10:40 PM
SB
Is this a new motor ? If so could be bypass sticking open for a few.
SB is offline
