Low oil pressure >
Low oil pressure
Low oil pressure
Old 05-08-2015 | 05:54 AM
It has 350hrs
Beachwood is offline
Old 05-08-2015 | 02:26 PM
ROB FREEMAN's Avatar
when you change that oil . cut open the filter n look for signs of bearing material .
ROB FREEMAN is offline
Old 05-08-2015 | 08:52 PM
Originally Posted by ROB FREEMAN
Get a mechanical oil pressure gauge. Shoot the oil filter after hard run with laser temp gun. It also recommend Mobil one v twin oil. It doesn't break down under high heat load conditions . Just a couple suggestions. Good luck
I agree with verifying psi thru a mechanical gauge. What oil are you running now?
Ryan00TJ is offline
Old 05-08-2015 | 08:55 PM
Im not sure i just bought it from a friend .i believe it may be 20w40 the oil looks good. Bit when i get home from work in a couple of weeks i and going with 40w and good filter. Im thinking maybe changi2out the oil sending unit as well.
