Fuel pump Q? >
Fuel pump Q?
Fuel pump Q?
Old 05-11-2015 | 07:48 AM
Default Fuel pump Q?
I have to change the fuel pump on my sea strainer! Maybe a dumb Q? But I've been trying to get the holley 110 GPH pump # 712-454-11. No one has it and the local store has the 12-454-11 but its for the car no vent tube! Well my vent tube has been pluged and not working sence last year! Any how I just freshend the motor and need to change it! Q? Is can I use the 12-454-11 or just order the right one, and wait a few more days! Either way no biggie the other one is just here if I can use it with no vent tube?
Mike S. is offline
Old 05-11-2015 | 08:04 AM
SB
1 left in stock. Hurry !
http://www.amazon.com/dp/B000M27VQC/...l_6pxnaqcmi7_e
SB is offline
Old 05-11-2015 | 09:00 AM
I'm assuming the fuel pump you have is on your sea PUMP, not sea strainer. If so, a regular holley pump designed to be used on the engine block, won't work. The arm is different
MILD THUNDER is offline
Old 05-12-2015 | 09:18 PM
Mild thunder! Thanks didn't even think about that! How much H-power do you think the stock pump will support?
Mike S. is offline
Old 05-12-2015 | 10:04 PM
so what pump fits the raw water pump?
dereknkathy is offline
Old 05-12-2015 | 11:02 PM
This one.
http://www.cpperformance.com/p-12460...6-engines.aspx
This is the only upgraded sea pump mounted fuel pump that I know of. Other than that, remove the pump, install a block off plate, and go to an electric pump.
Eddie
Young Performance is offline
Old 05-13-2015 | 12:45 AM
Stock pump from what Merc engine????
There are different part numbers for the fuel pumps on different Merc engines.
Griff is offline
Old 05-13-2015 | 05:47 AM
SB
Originally Posted by Young Performance
This one.
Eddie
CV products makes one. Many have used it.
http://www.cvproducts.com/Products.a...h=SPIN-MP-2630
A thread on OSO:
http://www.offshoreonly.com/forums/g...fuel-pump.html
SB is offline
Old 05-13-2015 | 08:04 AM
Ok so what's a good elec. pump that yall are running that will handle 600-650 hp with no bypass set up! Holley, aeromotive, magnafuel, etc. I wanted to keep my sea pump, pump but I guess I could go elec. he'll some elec are the same cost lol
Mike S. is offline
