454 MPI Random Power Loss >
Old 05-11-2015 | 08:25 AM
CIG3's Avatar
Default 454 MPI Random Power Loss
Posting this for a fiend of mine. 96' 454 MPI runs great then cuts-out like someone hit the kill switch then catches and starts running fine again. sometimes a 3200rpm cruise sometime at or close to WOT. Replaced cap, rotor and wires. Fuel separator had no water when replaced. Any thoughts????
CIG3 is offline
Old 05-11-2015 | 08:31 AM
sounds like electrical issue,maybe the safety lanyard switch or ignition switch.
mike tkach is offline
Old 05-11-2015 | 10:00 AM
Totally agree with Mike
Check as many of the Ground wires as you can. Something as simple as a battery connection could contribute to this issue. I did experience the exact same thing a number of years ago and it was the battery. Do the obvious- check the wires going to each spark plug -- sometimes they are not making as good a contact.
please let us know the outcome
Let's get this pup on the water and above all BE SAFE
3pointstar
3pointstar is offline
Old 05-11-2015 | 10:10 AM
CIG3's Avatar
Thanks for the tips. I will get over there and look at it with him this week.
CIG3 is offline
