O/T..any swimming pool  suppliers??? >
Old 09-10-2002 | 08:26 AM
Scarab3DMC's Avatar
Default O/T..any swimming pool suppliers???
Any pool guys out there??? I need a heat exchanger for a Hayward H250 POOL HEATER.. PT. #28L 40582..help!!!
Scarab3DMC is offline
Old 09-10-2002 | 08:39 AM
thunderdan's Avatar
I just happen to be one of those guys, let me check to see what my supplier charges me and that will be your cost....I will get right back to you.
thunderdan is offline
Old 09-10-2002 | 08:44 AM
thunderdan's Avatar
I am making a few assumptions here so.....
assumption one-natural gas
MY COST:
electronic-986.37
millivolt-933.60
plus whatever the cost to ship.
One other option-
I do not know how old your heater is but......
I can get a natural gas-electronic- heater-185,000btu my cost $912.79
or same thing but 265,000 btu $1012.71
These are both Ray Pac heaters-
Old 09-10-2002 | 09:24 AM
hp500efi's Avatar
Member #9
Scarab, takes Dan's advice and buy a new heater. Product will be new, new warranties etc....replacing heat exchangers are usually the point where a new heater is warranted.
Good Luck
Member of the Liquid Jungle
hp500efi is offline
Old 09-10-2002 | 11:26 AM
Scarab3DMC's Avatar
Well the heater is only 3 years old 250,000 btu w/standing pilot very good shape always pulled in winter and stored in the basement... I only need the exchanger no header ends... 9 tubes 2 leak.. my supplier said I must have low PH....I test strip almost daily...adjust accordingly....WTF??? POOL IS 30' ROUND 54'' DEEP.... heater was 1600 new....
Old 09-10-2002 | 12:17 PM
thunderdan's Avatar
Test strips are not that accurate, but if you had that low of PH you would know it.
I would guess it could be caused by the way you feed chlorine into your pool. Do you add granular chlorine directly into the skimmer or do you brodcast it? Do you put the chlorine pucks into your skimmer basket or do you have a feeder, does your feeder have a check valve in it, or not?
The heat exchangers, as you can tell is the most expensive part of the heater, plus that is how the manufacturer makes up the money...on replacement parts.
Old 09-10-2002 | 02:11 PM
Scarab3DMC's Avatar
Chlorine is fed thru a feeder ...with a working check valve.. 3'' TABLETS.... I'm gonna fabricate a heater buy pass , so when I'm not using the heater I can buy pass and not constantly flow thru the heater..... I run the pump continualy to keep the pool clean..I also run a polaris 65 auto cleaner
carney
06-28-2005 08:57 PM
