Installing mayfair add kit with the extra saginaw fitting kit, 6 in 1/4 hose missing
Installing new mayfair dual ram add kit with the extra saginaw fitting kit, 6 in 1/4 slide on hose and clamps missing... Is this jut a low pressure rubber hose? Will standard hose clamps work?
The instructions and diagrams show the hose sliding over/connecting lines that need to be cut on the Saginaw shuttle valve.
Thanks, Jim
Thanks, Jim
Just found out from the manufacturers that any 1/4 in id hose (fuel or other) a few inches long should work, clamps optional (I'll be clamping). Hasn't been an issue or included in kits for years, I guess I am running a dinosaur,,,,
