What cam button??? >
What cam button???
What cam button???
Old 06-12-2015 | 07:31 AM
Default What cam button???
In process of putting my engine back together and I installed a polished aluminum front cover instead of the stamp steel. I looks as if my cam button is too long. Current button is .940". Does anyone know what button will get me a little closer (I can machine off some of the cover for the right fit)
Its a Mark IV Roller cam
bigbird241 is offline
Old 06-12-2015 | 08:13 AM
i use a small block button with the edelbrock timing cover but you may need an xtra gasket or two to get the desired cam end play.
mike tkach is offline
Old 06-12-2015 | 08:35 AM
I will try that, thanks
Old 06-15-2015 | 07:39 AM
SB button worked perfect, thanks
