Torque Setting - XR drive bolts/nuts >
Old 06-18-2015 | 09:52 PM
Default Torque Setting - XR drive bolts/nuts
Anyone know the torque setting for the four nuts on the drive bolts. Bravo 1 XR drives.
Thanks.
imartin is offline
Old 06-18-2015 | 10:47 PM
If you are talking about the 4 bolts on the top cap, they should be torque'd to 20 ft. lbs. Tightened in a criss cross pattern.
Revd Up is offline
Old 06-19-2015 | 12:41 AM
BUP
Are asking about the studs and nuts for reinstalling the lower to the upper ? If this is correct and If I recall correctly, its 35 ft lbs.
BUP is offline
Old 06-19-2015 | 09:41 AM
That's correct. Gear housing to drive shaft housing 35 ft. lbs
Revd Up is offline
Old 06-19-2015 | 07:32 PM
Thanks guys, wow only 35. Would have guessed higher.
35 it is, thanks.
imartin is offline
