Prop Slip on a 36 >
Prop Slip on a 36
Prop Slip on a 36
Old 06-24-2015 | 02:28 PM
Leathl_WS6's Avatar
Default Prop Slip on a 36
What kind of prop slip numbers can I expect on my 36...
I'm seeing what I believe to be an insane amount of slip
28 pitch bravo 1 4 blade props reworked to 29's spinning 4100 RPM = 60 MPH = 20% slip
32 pitch bravo 1 4 blade props spinning 4000 RPM = 60 MPH = 26% slip
Will adding some cup to these get the slip down?
I don't have any WOT numbers...
I did make one short run to 5000 RPM with 29's and was right at 70 MPR or 24% Slip
What are you guys seeing as far as slip on your 36's?
Leathl_WS6 is offline
Old 06-24-2015 | 09:39 PM
14 apache's Avatar
Are these props all reworked? One more question if you put + trim in it will the motors run away? Have you ever had new propellers on the boat?
14 apache is offline
Old 06-25-2015 | 12:03 PM
Leathl_WS6's Avatar
Yes I believe both sets to be reworked. I have not had new out of the box props on the boat...
I can trim pretty high before they blow out it thats what you mean..
As I trim up RPM gradually rises and speed increases.. Max speed at 4000 RPM, is at around 3.5 on the drive indicators.
Old 06-25-2015 | 12:26 PM
How about a little two sided tape on the leading edge of the prop , you never know might work .
Cheers RG .
Rick G is offline
Old 06-25-2015 | 12:27 PM
Leathl_WS6's Avatar
Cheers RG .
Never heard of this trick... Will it actually stay there?
Old 06-25-2015 | 12:31 PM
No just having some fun . I have the same issue propping my flat deck cig. Don't know wether to reduce diameter or move up in pitch , it's an art not a science . RG.
Rick G is offline
Old 06-25-2015 | 12:39 PM
14 apache's Avatar
You need to try props that aren't reworked till than you wont know.
Old 06-26-2015 | 11:15 AM
Hessdk's Avatar
I am running about 18% slip with my 36'. My props were labded by BBlades. Make sure your RPM and speed are accurate before you run your slip calculation.
Hessdk is offline
Old 06-26-2015 | 11:34 AM
Leathl_WS6's Avatar
Can you tell me where you are? Speed pitch horsepower!!
I know these boats are heavy and not so efficient, but even 18% seems high.
Wonder if that's the norm??
Anyone else?
Old 06-26-2015 | 11:45 AM
If you have "reworked" props you really don't know what you've got. Try some props that haven't been "reworked" to come up with some more accurate numbers.
bobkatz is offline
