Exhaust Bolt holes blind? >
Old 06-26-2015 | 01:24 PM
seafordguy's Avatar
Default Exhaust Bolt holes blind?
Are all of the exhaust bolt holes on a set of 088 heads blind?
I just had to pull my headers off and on the even bank one of the bolt holes for the number 2 cylinder water poured out of the bolt hole......
seafordguy is offline
Old 06-26-2015 | 01:40 PM
seafordguy's Avatar
Never mind - I looked up in there and I know the answer.......
Old 06-26-2015 | 02:03 PM
SB
Some Chrysler exhaust bolt holes go into the coolant.
ooops.
SB is offline
Old 06-26-2015 | 05:46 PM
so fill in the details!
mike tkach is offline
Old 06-26-2015 | 06:26 PM
SB
Rot ?
SB is offline
Old 06-26-2015 | 06:59 PM
^^^^^^^^^^ that would be my guess.
Old 06-27-2015 | 08:49 AM
seafordguy's Avatar
Details......
Valve guides weren't cut down enough to clear the top of the seals that we used. Pulled motor, removed headers and water came out of one of the holes...... I know that head has been off before I owned it, and I'm wondering if they had to drill out a bolt and went too far.....
No idea really, but I'll pull them back off, fix it Monday, and hopefully have it back in the water by July 4th - I just keep pushing back which holiday I'm targeting - I started with a target date of Memorial Day, now it's July 4th.....
Old 06-27-2015 | 12:12 PM
If there is room for a standard 3/8" - 9/16 head nut instead of a bolt, I would just put a stud in there with some sealant on it. I put two studs on each head for my manifolds / headers. Makes life much easier when installing the manifolds - lines right up for you.
Budman II is offline
Old 06-27-2015 | 12:28 PM
seafordguy's Avatar
I'm thinking it would be pretty tight with the headers.. Sme of those are tighter than the others so I'll have to check
