Q-Jet to Hollry Carb Swap Question. >
Old 06-28-2015 | 01:43 PM
Default Q-Jet to Hollry Carb Swap Question.
OK, Almost ready to mount Holley, question is, On the Q-Jet there is the hose to the Fuel Pump in case of fuel pump diaphragm failure,
1) What do I do with hose?
2) How do I provide this protection for pump failure?
(GEN IV block mounted mechanical pump).
Thanks in advance.
GLENAMY 242SS is offline
Old 06-28-2015 | 01:59 PM
14 apache's Avatar
Flame arrestor normally has a spot or you will need to add it. Take a look at some pictures of flame arrestors to see.
14 apache is offline
Old 07-09-2015 | 08:12 AM
I have the Hardin Marine Polished 8x12" Flame Arrestor. No provision and no real recommendations.
I have come up with a VERYclean professional looking solution using $5 in parts.
If anybody else is interested, the special fitting (you will not find this in your H/W store) barb-compression w/bulkhead 1/4" -1/4" from Parker 22CABH-4-4 Bulkhead Union. and 1/4" copper tube 6" one hole in bottom plate and some shaping of tube.
Pics if you are interested. PM me.
Hope this helps others.
Old 07-09-2015 | 09:17 AM
A spare holley marine carb bowl vent from a trashed 650 will get you there in a pinch also
airjunky is offline
